Ben's 73 Build Thread
Bferrari
Bferrari
Just finished the Drivers side graft. Figured I would do a little better job of documenting how I did it so here it goes. I began cutting the wheel arch out of the old fender, leaving the style line so I could match the body line to the rear. I then placed it over the front fender and with a string line found center of the wheel arch.
Next I hung it on the rear quarter and matched up center and the body line, and checked level in the wheel arch, matching it exactly to the plane of the front fender.
I wanted the flare to blend in with the lower quarter so I marked and cut.
I used the lower front portion of the cutout to weld back in so I could retain the lower radius. This left me a small section that required forming. Welded both of them in. Also trimmed the lower rear and welded it in as well.
I marked the outer edge of the graft, removed it, then marked and cut about a half an inch inside the line. I next used an air notching tool to put a recessed lip around the cutout for the graft to sit in.
Bferrari
Bferrari
Welded her in, jumping all over to minimize heat and warping.
Ground it down to prep for body work.
Shot some primer on it to keep it sealed until I get going on the body work.
Bferrari
Bferrari
The fun continues ... yanked the body back off of the frame and put it back on the rotisserie for the final welding. I set a personal goal to have all my fab done by March 1st so I could begin the body work ... came close but haven't made it.
I began with a small repair to the passenger side inner rocker, cut it, treated it, patched and welded. Then I moved on to the replacement of the two core supports that are under the battery and filled all of the holes in the inner fender.
Next I moved on to patching the old speaker holes in the doors then rehung them on the body.
IMG_5736.jpg IMG_5737.jpg IMG_5739.jpg IMG_5742.jpg IMG_5743.jpg IMG_5752.jpg
I then finished the night off with installing weld nuts to the inner bed rails so that the top installation and removal will be easier.
I've still got some odds and ends to finish with filling holes, patching the side markers (I don't like them so they are gone), etc. then on to the bodywork. The goal, although it may be unrealistic, will be to have this thing ready for paint by the beginning of April. Cross your fingers and wish me luck!
broncoitis
Damn, nice job on everything so far. My fingers are crossed for ya. Body looks like it is pretty straight so hopefully will go smoothly! ;D
Bferrari
Bferrari
Thanks! I'm hoping it goes quicker than I am anticipating. It is really straight but I tend to get very critical on work like this!
Jc.av8r
Nice progress. I am just a few steps behind you, can't wait until I see a full body again with nothing but clean metal and no more holes!
Bferrari
Bferrari
I hear you brother! I've had my fill of body panels .... I am ready to move on to the fun stuff!
Bferrari
Bferrari
Welded in the marker lights and spare tire mount holes.
Next I proceeded to fill the extraneous holes that will not be used in the windshield frame.
Now I am at a point where I need to figure out which holes I am going to use in the firewall and which ones I can eliminate. I started by pulling the totes down off the pallet rack and am in process of reinstalling a lot of the stuff I am going to reuse to verify hole locations. I also need to do a little homework and plan my execution of the wiring harness, AC/heater core, throttle cable, etc. as to identify any other holes/deletions that will be necessary. It feels that every step closer I get, the further I get from getting this thing into paint! Time to cinch up and get'r done!
englewoodcowboy
Lick Creek Restorations
Nice job. Do I see burn marks indicating the windshield is now permanently mounted?
englewoodcowboy
Pat yourself on the back.. You got a lot done... I will be washing mine in a few hours... :)
mattyq17
Ben, can you post some pictures or text them to me of how you welded your w/s frame on. Its on my to do list once I get the bronco back out to the ranch. Thanks
Matt
Bferrari
Bferrari
I've been busy test fitting everything and have made a lot of progress toward identifying how I will route everything. Sent some time and got my wipers working, used a jump start pack to run it through the motions and it is up and functional. Next I moved on to my passenger seat mount. I have two little ones and want to make sure I am able to easily load them up in the back. Since I will be using 'non-stock' seats (mainly due to needing a lower seat so I could see out the windshield) I fabricated a mount that will enable me to get the clearance I need for rear seat access.
I still would like to get the drivers seat mounted, rear seat modified and mounted and my cage built prior to painting this thing. Hopefully I can get through these items quick so I can jump back to the body work and get this thing in paint.
Bferrari
Bferrari
Was able to get the drivers seat mounted today. I am getting excited, the seats fit great and are much lower than the stock ones!
englewoodcowboy
That is awesome! I am glad to see you have gotten a few days in your shop. Are you doing a tilt column? Just looking at the clearance addition that you have with the stock column and wheel is quite significant. Looks pretty comfy!
Bferrari
Bferrari
Definately going with the tilt column, just threw the old one in to see the difference in seats. I think these are going to work out real well.
