Bent Ford 9 Housing???
EricLar80
I was taking a look at their website doesn't seem like they have a Bronco specific housing? Am I wrong about that?
I'll probably most likely get the Wild Horses Super 9 Housing
You just order their generic housing and put in all the specs you want. Will allow you to customize brakes or whatever you want. My guess is this is where WH gets their housings from.
Johnnyb
Flagstaff
Agreed, I seized a bearing, broke a shaft, and the only thing that got me to the side of the road safely was my disk brake swap. Caliper kept ahold of the rotor so the tire didn't pass me.
I experienced the tire passing me situation in central Nevada. After sparking to a stop on the backing plate in the middle of the road, I was able to use four-wheel drive to pull the EB to the shoulder. The tire was in a field almost half a mile away.
Never could make bearings run right after that. Just got my new axle housing from wh, can't wait to get it installed.
Sent from my SM-N981U1 using Tapatalk
