Took some measurements on the 75 because it looked like it had a nasty case of the bronco lean and I find that the passenger side of the frame is at least a .5" higher than the drivers side rear. They were measured from the same spot, Checked the front end of the frame and it is spot on. Any easy way to correct this without taking it to a body shop??
thanks Ben
thanks Ben
