Good choice. Get the ones for the 80-96 Bronco though, the f150 has different mounts out back. When I got this 74 They had installed black eb poly mounts and 3" body lift pucks over them. Those were already squashed down a bit with just the body sitting for about 3 years. These bodies are heavy and add a cage or other things and it's really too much, I just installed new poly transfer case mounts, search the thread, " what have you done to your bronco today". Look up Mofoco1 you can see pictures of what the originals look like or what's left. Change yours to poly as well, worth it! Understand the engine fit issue. I still have the 302, but went with a mid rise AirGap intake, a Demon carb, and an oval Billet Specialties open air cleaner. If I had taken the Body lift off I would not have been able to use that combo, so I left it. What I did decide was to ditch the 3" composite blocks in favor some custom made and sized 3" dia. aluminum body pucks atop of the BB poly body mounts. Since they were taller I had the size of the puck made shorter to allow just enough room for the air cleaner to clear. I wanted no BL but couldn't get away from it. I am making new bumpers that will use the old bumpers as covers, the mounts will be raised so it will still have the stock height appearance that both you and I are after, as mine is a Luber. Check my garage might give you some ideas...Mo
