2 years later and I am going to do the locker.
-Since the best type of locker is the arb type in which it can be switched on/off.
There's no such thing as "the best type of locker." A selectable sure seems like the best locker choice for the front axle of a truck that could be driven on snowy highways, but in other applications an automatic locker has some strong points in its favor as well.
-What are the thoughts on the Ox locker?
-Reason being, the ARB needs a compressor/electrical etc (lots of moving parts)and I like the mechanical approach of the Ox locker.
No personal experience with either the OX or the ARB, but several I've talked to think the OX is a stronger unit. And the options it gives for activation are great as well. I am planning to put an OX in the front of my Bronco, hopefully this spring. Personally I'm not sure I want to with cable actuation. Routing a cable so it doesn't bind or get damaged seems like it could be an issue. I already have on-board air, so I think I'll go with an air actuator on the OX. But even with that it gives the ability to manually engage it (by crawling under and screwing something into the actuator hole), so it still has an advantage over the ARB there.
-I still like the trutrac, but as some stated it may not be best if I get caught on the ice.
I wouldn't worry an awful lot about a TrueTrac on ice. In a rear axle even an automatic locker really isn't very bad. My biggest concern with anything but an open diff (or unlocked selectable) in front is the torque steer you get when one front tire loses traction. I know from experience that an automatic locker is really dangerous in that situation unless you are going pretty slow. Others have said that a TrueTrac doesn't do that, and it makes sense that it wouldn't be close to as bad as an automatic locker. But it seems like it has to have some. Even Eaton seems to think it's a rrisk, because they make a less effective TrueTrac for front applications (which might be a great choice for a front application).
-I have a duragrip in the rear, should I change that out or will it suffice with a nice front lsd/locker?....
Up to you. Personally I think clutch-type limited slips are the worst of both worlds, the stability of a spool on ice and roughly the traction of an open diff when you really need it. I think even an open diff would be an upgrade for you, but I know others have different opinions on them.
For general on-road use with snow likely, I don't think you can beat a Truetrac. But I also have around 200,000 miles of experience with an automatic locker in rear axles (CJ5, F-150 and Bronco) and I wouldn't hesitate to use any of those in winter driving either (other than the salt on the Bronco body
) And a lot of people like selectables in the rear too. I really think any of those (or an open diff) would be a better choice than what you have. But that's my opinion.
