best dui hotwire location?
75
Speedwell TN
got a dui to clean up the engine a bit and obtain a hotter spark-but just where are these things best wired? can a fella use the starter motor relay-the post that DOES NOT attach to the batteries + postor run it to the ignition swith where they resisor wire was attached. its a stock 76 electrical system now. thanks
astark
Bronco God
I run an MSD, but thought DUI had to be switched too. I checked the DUI site and it does say any 12V source though. Check your instructions or call DUI Monday and make sure. But I think it needs to be switched and at the ignition is probibly going to be your best place.
Anyone else, for concensus.
PS I just tried calling DUI at 901-396-5782, but got no answer. I'm with the poster above though in thinking it needs to be switched.
Here is a link to their web site http://www.performancedistributors.com/
SteveL
Huge chevy guy
Hawthorne ca
I have the centech wiring. It comes with a wire specially for the DUI. I believe it is of the ign sw.. Run an extra wire for a tach if you donn't already have one.
75
Speedwell TN
it does need to be switched on so the ignition switch looks to be the best bet. called the company and the dude is nice but used a lot of technical electrical jargon on me, never said anything as clear cut as --starter switch. thanks guys
