Hey Jim. Welcome to CB if you haven't been already.
No matter whether you choose a kit with some GM components, or go all Ford (knuckles out), the hub, rotor, bearings and inner bearing seal are all the same as if you were ordering for a 76 or 77 Bronco.
Only the spindles, pads, calipers and backing plates would be certain early to mid-seventies GM.
You can source any and all parts from the junkyards of course, but the early GM stuff has been getting pretty scarce around this area lately. And the Ford stuff is not far behind.
As has already been said, for certain parts, only the Dana 44 versions are compatible.
No other full Dana 44 housing or axle shafts are a direct bolt-in except for an EB 44 housing, and some short side axle shafts from a few others. Knuckles though, are very compatible across the varied lines of Dana 44's of that vintage. With just a few exceptions.
But it's the spindles and brakes you have to really watch out for on most.
The '76 and '77 EB knuckles, while compatible with both the disc brakes and your 44, have wider spaced steering arms with smaller tapered holes for the tie-rod ends. So using them would work, but you would have to ream out the holes and choosing the right wheel offset is critical.
Knuckles from the full-size Ford trucks and Broncos are a better choice, but still have some differences you need to compensate for.
The tapered rod end holes on these are actually larger than your existing ones, so you would either need to use tapered sleeves to fit your existing tie-rod ends into the larger holes (such as our
http://www.wildhorses4x4.com/product/Tapered_Sleeves_for_F150_Knuckles ), or utilize a custom tie rod setup (such as our
http://www.wildhorses4x4.com/product/Tie_Rod_for_F150_Knuckles_Two_Way_Adjustable ).
If your existing steering is in good shape, the sleeves are a simple solution. If your tie-rod is already in need of replacing, then the one we offer is another simple upgrade. If your stuff all needs replacing anyway, then there are many different upgrades offered by us and the other vendors, as well as custom stuff you can build yourself.
Lots of info about that hereabouts too.
Not to get you away from any Duff stuff (well, ok, just a bit maybe
), as they and the other vendors all have good product. Just letting you know what's out there. Some of which at least, from us. If you have your favorite, by all means give them a call for details you need. Duff's 01Dudley is a member here (and Suzy too of course), as are some others. So they may chime in here at some point as well.
Just some options for you.
