70_Steve
Old Guy
- Dec 13, 2002
- 8,317
So I'm finally getting things back together... Newly rebuilt engine back in the truck, EFI conversion basically in place, transfer case rebuilt/repaired. I would have had the engine running last weekend, but a patch welded on a corner of the oil pan leaked, so I bought a new oil pan, along with a one-piece gasket. The first project today is to install that new oil pan.
I get the oil pan and gasket out, and layed the gasket on the oil pan. Now I have a concern that the gasket may not install correctly at each rounded end of the oil pan. I've been trying to decide whether to wire the gasket up to the block, and fit the oil pan to it. Or, do I attempt to push the oil pan up into place with the gasket taped? to the top of the oil pan. I was thinking of using a bunch of small pieces of masking tape in between each bolt hole to keep the gasket in position while I put it up into place. But still my biggest concern is the rear of the oil pan, where I can't see it once it's up in place.
Anyone care to share their best method of reinstalling the oil pan, insuring the gasket stays in place???
