Bestop doors:
Ryans71
Milton, Wa
Do the bestop doors work with the STC top? I hate my STC doors and want the bestop doors..........but I have an STC top.
Ryan.
AWS
ST LOUIS
I run the Bestop doors with my Kayline/STC top. I even ordered them to match the old school vinyl. My biggest complaint with them is, once you get above 45 mph the tops blow open. To fix this, I have made latches to secure the upper door in two places. Now I can do 70 mph and my heat stays in.
Steve
BroncKrawler
Harrisburg, Oregon
I had the same problem with the upper portion of the door sticking out too far when I'd reach speeds of around 55 mph. To fix it I just bent the two rods that slide into the lower part of the doors to keep more pressure on the soft top. Now they work great and seal good too
Scoop
Bronco Old Fart
Cuchara, CO
Steve
Steve, I've been working an idea on how to keep them from sucking out at speed - looks like you beat me to it! Can you post pics of your latches? I was thinking of using some velcro straps.
Sorry for the hi-jack, I am running Galen's doors (same as the Bestop) and, like AWS, I have the older Kayline top. Fits well except for the aforementioned problem.
Scoop
Bronco Old Fart
Cuchara, CO
I actually bent my upper door frames so much I had to install a tab on my windshield frame to keep the doors from coming IN! But they still get pulled out at speeds above 60 or so. The frame may be a little beefier on the Bestops compared to the earlier Galen doors.
SnwMnkys
Orem, Utah
Do the bestop doors work with the factory hard top? Ive been wanting to order a set, but i dont own a soft top.
AWS
ST LOUIS
Gary here are a few shots of the latches
