bbfarms
pulled the 69 into my shop, took the bench seat out, and the hard top off. Had the doors open whille doing this proces. After the top was off and seat was out, went to shut the doors and SURPRISE>>>>>>neither would shut correctly, there is about a 1/2 -3/4 gap at the bottom of each door and rubbing at the top (back of the door) The floors are shot, and the cross member behind the seat, just in front of the bed floor is gone. Got a 1x3 tube to replace it with, and some heavy steel that I was going to replace the floor pans. Should also not that the rockers are shot and have new ones to replace.
If I replace the cross member and put new body mount will this fix it (assuming I can lift if straight)
Has anyone ever added "extra" steel inside the rockers to help support?
Will "thicker" body mount bushings help (in the center)
Body cages??? ( want to use the stock doors) and possibly a soft top
I want to do a good job with out a money pit and not concerned with show truck qualit, just wanting to do a restor to a daily driver.
Also sould note....have acess to allot of steel and my own Miller MIG and no stranger to Fabricating
Any other ideas?????
