bilstein shocks question
Wildcat
i ordered four new bilstein shocks (FE5-6248-H5, 10" travel) but when i try to install them they extend 4" past my shock mounts. Is is ok to compress the shocks 4" to get them to fit? or should I order shorter shocks? Thanks!
W
Wildcat
by the way, the distance from mount to mount is 21" in the front and 23" in the rear.
wildbill
Old Bronco Guy
;D ;D ;D If a shock is all the way out and you hit a good bump you will brake the shock so yes it should go past the brackit or it is not the right shodk good luck.;D ;D ;D Bill :cool: %) :p
72bronco
You didn't say if your bronco was stock height or lifted. Having 10" travel shocks may be a bit much for a stock height bronco.
