Black Cloud Boob Job Build Thread
sstclair
Ok....been thinkin' about it and I think it's time for a new name. This has become an entirely new rig.
I'm thinkin' KillaHorse....since it'll be a 1000hp Bronco. Whatcha think...gay or not?
KillaHorse is close but I think it leaves a little much on the table.
I'm thinking you need a name contest on here. And once it's finished, offer out the stud services.
Something like BAMF for Bad Ass Muthu Ford comes to my mind.
-Steve
C
coby
Fort Collins, CO
Not quite yet. Got a somewhat new addition to the parts pile I didn't want to announce till I had some pics to share. Ya'll are a bunch of pic sluts, yanno!
Here's the first hint of the next round of parts porn that I was alluding to earlier.
C
coby
Fort Collins, CO
I think it is an engine block.
Give that man a cigar. Not just a Dart block, but the Dart Iron Eagle block.
So, yea....putting together a new long block.
Took a good hard look at the current setup and admitted it wouldn't hold up to an honest 1000hp at the crank. Not with that 2 bolt main setup and not with that modified 400 crank. So...
Dart Iron Eagle block steel w/ main caps 4.125 bore
Lunati Pro Series Crank 4.00
Lunati Signature Series 6.250
JE Forced Induction Dish Pistons
Total Seal Steel Ring Set
AFR 225 CNC heads
ARP Head Studs
Comp Cams RH blower cam, Retro Lifters,P-Rods, Rockers
ATI Balancer
MLS Head Gaskets
MUCH stronger bottom end...Lunati crank and Dart Iron Eagle makes for one hell of a combo. Even better flowing heads than those ported Trick Flows I have on the N/A motor...the AFR's fllow a ton. And we're going with 9:1 compression ratio, instead of the 10.5:1 that I've got in my current mill....that'll help guarantee working with pump fuel out in the boonies. And my old mill was 4.125" stroke and 4.04" bore...this is a bit less piston speed by reversing that. It'll now be 4.00 stroke, and 4.125" bore, for a bit over 427ci that the big blower will be shoving huge volumes of compressed air into. Cam's got a lot of overlap, so it ought to be fairly tame at idle and controllable which is what we're looking for, but when the go pedal is pressed, the blower bypass shuts off and the fuel pump ramps up to full output and all hell breaks loose. Yippee ki yay mothersucker.
I'm going to try to coordinate with the machine shop to get pics while it's getting torque plate honed and aligned bored....those'll be fun shots. The B.R.O.N.CO club will be holding a meeting there at the speed shop while it's getting dynoed towards the end of the month. Ya'll folks down in the Denver EB group are welcome to join us if you like...outta be fun.
Here's another pic of the splayed bolt 4 bolt mains in the block that came in today. Dear lord it's purty!!!
AaronB
Longmont, CO
More Fab
I designed the front suspension and had Coby "ok" the initial numbers. Let's just say space is at a premium. Tight tolerances for sure. Got the brackets welded up and tacked into place, then made a couple links for mock up.
With the links in place, we were able to cycle the front suspension. We added some cardboard tires to help check our clearances. It flexed well and predictably, we should be able to dial it in with ease.
AaronB
Longmont, CO
Did I mention how tight everything was? Just past "full compression" on driver's side:
And also mocked up driver's position:
Isn't that T-case sexy?!?!?
C
coby
Fort Collins, CO
Ah, frustrations. Hogan's intakes hasn't been responding to my emails and they've not delivered the custom intake yet. Called them today and chewed them out for not answering the emails and they said the president was working it and was responsible for communicating....GAH. I need at bare minimum height of the unit.
Engine parts are slow in coming in as well. We've gotten a few. The heads came in yesterday; I'll shoot some pics when I get a moment to drive down either tonight or tomorrow night. Aaron's been working with the rear axle; I'll let him post up some pics of that...they're up on the mostlyharmless.smugmug.com site. Advance Adapters still hasn't hit my card for the payment for the transfer case....crikey they're slow.
Happy 13th, ya'll. Here's a couple of pics of the kickass fuel pressure regulator with motor feedback, the fuel pump, oil pan (nothing special), rockers, timing chain....the usual stuff. I'll apologize in advance if the pics are boring...I get a kick out of the most pedantic parts; I like looking at metal. LOTS more pics at the main boobjob pic site, as always....the ones I post here are just a select few.
C
coby
Fort Collins, CO
(this is carryover from the similar build thread on Pirate....wanted to share the pics here)
Originally Posted by Lee N
RPM is your friend! I think you are under camming the motor. Are you worried about low TQ numbers on bottom with a bigger cam? I would let that baby breathe Coby! You have so many cubic inches and boost!! Your torque curve will be through the roof on bottom even with a big cam! If you are only looking for 6000rpm peak you have the wrong heads! The AFR 205's will sing to 7000 (mine peak at 6400)! Those 225's want some cam!!! To move enough air to get into the 1000hp range you need to be singing above 7000rpm! With the cam you have I bet you a 6 pack you don't get over 750 at the crank. My dart block stroker is running .680 lift and duration at .05 of 266 int and 276 ext. We pulled the dyno way down to 2000rpm and TQ was still over 450 (and I dont have boost).
Coby: I'm worried about accuracy at lower rpms, detonation, and running cool with big horsepower. I'm also concerned with lifter pumpup above 6500 for the hydraulic roller lifters. You gotta remember that these heads will be seeing more air going through them at 3k rpm than yours do at 6k rpm. I'll post up some of the charts I've been seeing playing with Engine Analyzer Pro...last night I was running up charts with severely retarded timing while advancing the cam a bit to get the detonation likelihood into the safe range while trying to manage the overlap leakage. The numbers are good....I can get to 1200 hp fairly easily but not with the likelihood of detonation that I'm comfortable with, and at slightly higher pressure than I was shooting for (16psi....I'm hoping we can do it at 13psi or under). If I can hit my target, while keeping RPM reasonable, torque curve broad and flat with HUGE torque off of idle, keep compression down and heat down for normal driving while on the blower bypass...well then hell...it's a win.
BTW, here's a teaser pic of the new AFR heads for ya'll that haven't seen them....I'll post more later today; I have to get some actual work done for a little bit. I get a kick out of the pattern the CNC cutting leaves for the contoured sections.
Comments on the data in the EAP results welcome...still tweaking it and trying to make it realistic for good predictions.
