Block plate....plate between the block & trans
Bronk74
North Las Vegas
I recently installed a C4 automatic without knowing I didn't install the BLOCK PLATE between the block and the trans do I need this? or can I still run without it.
Tom
76 bronco J
yes --it protect the block somewhat,keeps started mounted in correct relationship to flexplate or flywheel front to back & side to side, keeps bell housing depth correct
Bronk74
Bronk74
North Las Vegas
block plate...easy to install?
since the motor and trans are already in. where does the plate mount? behind the flywheel on motor or can I just seperate the motor and trans and slide it in between.
