body aligment
cantrem
Hey just did a WH 1 inch body lift and I have read you need to take measurements to get the body aligment right. I am not real sure where to take the measurements, any advice would be greatly appreciated. Also do you normally have to change the lower steering shaft? The instructions said you wouldn't but I have quite a gap there(took it loose at the rag joint). Those old body mounts were lovely.
chuck489
Dahlonega, GA
I just did one and the only thing I had to do was adjust the C4 linkage. There is a nut on the transmission side of the linkage and it had enough adjustment. My Bronco body wasn't perfect before the lift install, and we discovered three of the factory pucks were gone. My gaps didn't change once the lift was on.
Gerbow
Jacksonville
If your talking about alinging the body on the frame, i would say you can probably just take measurements from the frame to a body point from one side to the other til you get everything with the same #. Just measure from exact same spot at on each side.
Hope that makes sense to you.
C
cantrem
Yea thats what I'm looking for body to frame alignment, any advice on movin the body around?
Gerbow
Jacksonville
Last time I did one, I was able to just give a shove here and there.
Someone else may chime in with something easier.....
WorkerBee
Northern CA
I just installed the same BL. I drew a quick diagram of the top view of the truck. I measured as many points as I could in both the L and W directions. I tried to find easy points to reference from and wrote the dimensions down.
When I had all the new mounts installed (loose), I isolated the body on four piano type dollies with the weight off the mounts, I was able to move the body around with ease in any direction.
As far as the shaft goes, I had to add a U joint I got from an old F150 at pick and pull. The change in geometry would not allow me to simply loosen the support bolts and re-tighten. I hope this helps.
spap
A shove a little back and forth is what I did. You can tell where the old isolators were just make sure your new ones are in the middle of those spots. Also when you think you have it lined up take a good look about 15 - 20 feet in front and just make sure it looks right
needabronco
Prescott/Farmington
You can also use body washers (from the hardware store) to use as spacers under the body mounts to adjust the door gaps. The ones I use are about 1/8" thick.
As for side to side movement, the body doesn't weigh that much so you can just push it around.
