Body disassembly ?
agent_orange_71
Bluefield, WV
I hate to sound like a moron here, but I really dont want to jack my bronco up. Im getting ready to pull the body off the frame and start cutting out the bad panels. Im a retard when it comes to body work. What kind of measurements do i need to take. Ive already taken a million pictures so i can see how things go together. Anybody have a good body work write up or a list of measurements??
Jeepster
my lord...you think your up to it? Its my opinion that if your gonna remove the body and then slice and dice the metal your gonna have to weld some braces here and there so you dont totally wack what ever alinement you currently have.
Blue71
Pictures are good, but you need measurements. Especially since there are all kinds of areas of rust and even hidden rust on the 30 year old trucks. Brace everything that you can, especially around the door post and door opening areas. (You want your doors to fit when you put the body back on!)These areas are weak when the body is off of the frame. I'd even brace between the right and left bedrails...when you remove the top the sides the rear quarters arent quite as strong as teh would be with the top. A single brace would help there. All of these areas can drop, sag, lift , spread, etc when other parts of the body are removed or the tub is lifted off. I braced mine and cross braced it. It really helps. Take measurements before!!! With measurements and pics, and the help from this site. You will be able to get through it fine.
Good Luck,
Blue71
