Body lift or not?
jckkys
If stock bumpers,fan shroud,etc.are used;how much can the body be lifted before the space between the top of the frame-bumper and the bottom of the grill looks a little odd? Before the rubber discs on my 68 deteriorated this space was only about 3/16". Now the grill is touching the frame. I want to get a 1/4" to 1/2" clearance but 1" is too much and that's the smallest body lift available. Assuming that urethane discs deform less then rubber, would simply using these give me the small lift I want? The alternative would be to place a urethane disc under the bottom rubber pad. This would amount to a 3/4" body lift with the body isolation of the stock mounts. Has anyone tried a near stock + body lift?
My goal is to address the short comings of the original without creating a new beast. Ironically that's my way of being different.
Apogee
Tangent, OR
You could always just replace the body mounts with new, stock height mounts and then shim as you see fit. If it were mine, I'd go with a 1" BL incorportated into the urethane body mounts like WH's kit, but you can be as ironically different as you like.
bknbronco
North Metro, MN
if you want it stock looking then go with stock rubber bushings. If you need more height then add a washer or two. If you want a body lift then go with WH built in 1" body lift mounts.
This is the bumper to grill clearance with the 1"BL from WH built in to the mounts.
J
jckkys
My bumpers are like new painted type so I want to keep them. After seeing the look of the 1" body lift I'm back to my preference for 1/4" to 3/8" using washers. The WH 1" kit should provide most of the needed parts. I need about 1/4" added hood clearance to use the original air cleaner on the 351w. Now the air cleaner comes within 1/16"of both the hood and the valve cover when set at optimum height. Thanks for photo.
ep67bro
Bronco Junky
Easton, MD
WH 1" body lift. Every bronco I build from now on will have it. It is not real noticable but it gives you a little more space under the hood and in the wheel wells. Also its cheap and wont require any major mods.
Thunder Chicken
X2 ON THAT !
easy... cheap..improves looks and makes working underneath a lot easier!
