Mikes71bronco
- Nov 9, 2014
- 28
I ordered a new set of polyurethane body mount bushings from summit. I do not have a body lift and all the old bushings and hardware are original. My question is this. Are the rear 2 bushings behind the back bumper and to the right and left of the gas tank the same size as the rest of the bushings? Or simply , are all the bushings the same size? I would assume they would be but upon starting my project & removing these rear bushings the gap between the top bushing and frame is about a 1" or so. I inspected all the other bushings on the truck and all seem to be similar to the new ones bought. Only dry rotted and old. I wanted to get on here and ask if anyone has replaced these bushings and run in to this. If so did they just get the bolt started and tighten it down to pull the body, bushing and frame together? As always thanks for any of your time and input.
