Hey guys,
I hope some have you been where I am at now currently. My bronco was sandblasted, then sat in my garage for awhile here in Montana - low humidity. We have been slowing tacking minor body work - but it has been 6-9 months. I had a discussion with a local body guy who told me I needed to get primer on the body ASAP to keep surface rust from popping. He told me to spray it down with acetone and then spray Epoxy primer on it - then continue to putt along with the body work. So I was able to get the hood, fenders, grill, tailgate done - but I have not tackled the body - the guy who was helping me spray it is off to school so I have no gun to shoot with as it was his dads spray gun. I had another reputable guy stop by and throw me a quote to finish it - no way I can afford it. We did seam seal the body with POR -15 - the guy that stopped by told me I need to take it out as the primer/paint will not adhere to it - also the body has some minor surface rust showing up now.
So I went to CarQuest and bought acetone and 5 cans of etching primer - I was then out working on removing the POR-15 seam sealer on the rear quarter panel - for good measure I applied more metal ready to zap the rust - then I started to panic that it may affect the primer. I am now thinking I need to just buy a gun and spray the Epoxy as I have been reading other posts with the Gurus saying not to use spray can Primer ever.
So my questions are:
1) I am going to eventually spray a single stage yellow - what gun would you recommend for me to use to spray Epoxy and singe stage yellow paint? I am hoping not to spend much as I will only be using it for this. Any good website to buy it from?
2) Is that metal ready going to screw things up? Does the POR 15 seam sealer need to come out? DO I acetone over the metal ready?
3) Anywhere special I should by paint online or do I go to the local shop??
Thanks in advance guys for your tips with this!!
BC
BC
