Body work challenge
Dbarnes72
Eastern Wa.
I've finished up the drivetrain and getting ready to tackle the bodywork. Aside from typical floor replacements I have this extra challenge....both sides in front of the rear tires are hosed on the lower quarter panels. I may learn how to shrink metal before this is over. Any suggestions?
Broncmeister
you could you cut out the lower quarters and replace them with new skins from one of the vendors. That's what I'm doing on project #2
ehumaui
X2 on that, depends on what end product you want. I have done the replacement lower quarter panels on two trucks. If you were closer, I have the cut outs from my 74. It's almost the entire lower quarter, un cut stock.
Rc
Dbarnes72
Dbarnes72
Eastern Wa.
I'm putting flares back on it. I just don't want the pound of Bondo in there if I can help it. I toyed with the idea of going LUBR on it but I think for this one I'll keep it simple. I'd be happy to just get it evened back out but it's got a heckuva curl to it. Anybody got one of the braces that go in that position? Just cut out the #1 brace with my air chisel. I love that thing!
After you pound it flat and if the metal stretch is too much before you go replacing metal take a saber saw with a fine blade and cut a single slice into the stretched area. cut from the wheel opening through the center of the stretched area. Now take your mig and weld up the cut starting from the center to the wheel opening. weld an inch and let it cool off then weld another inch. Keep going until you reach the wheel opening. This will pull it in. do not hammer out the excess weld just cut the top off with a cutting wheel in your grinder this way it wont over heat the metal while removing the excess weld. then use a 36 grit wheel to smooth the area for finish body work.
