BooneBronco
- Nov 14, 2007
- 17
Looks great thanks for the info.
This sounds like an easy install, but is it all easily obtainable parts at my local parts store? If not, finding the stuff is usually worse than fabbing something up that is needed.
After installing a few of the rear disc setups available, I decided there has to be a better way of doing this.EVEN for us bearing challenged individuals. (guys with small bearing rear ends.) Machining axles and bolting rotors to rear of axle does not cut it with me. So, I went on a mission to find the true bolt on rear disc setup. Had to be Ford, Parts readily available and no messing with the axles or axle ends. Rotors had to fit on the STOCK Bronco axle end. After much searching and digging and trial and error, here it is Lincoln rear setup with Crown Vicky rotors!! absolutely no axle machining!, no welding!, no fuss no problems straight bolt on!! Two small alterations and it is in!! Pictures for proof. One picture shows my template for redrilling the rotors to the bronco bolt pattern, strongly recommend you make this. remember no axle machining was the rule and this meets it hands down. After figureing this all out I converted my small bearing, drum brake rear to rear discs in a little more than 3 hours. (well not quite but thats another story) This alteration could be done to a large bearing rear end in less than 2 hours a side.
TOFIC
Im running rear exployer brakes and having a hard time finding finder rotors. I have a big bearing axle (torino style) and can't find rotor 5x5 1/2. Will any of these rotor work on my rig? Thanks Jim jfoster1500@sbcglobal.net
Jim: If you want Explorer rotors that are drilled to the 5-5.5 pattern, you can get them from Currie Enterprises.
Todd Z.
Hey Todd::!
Good to hear from you, got a question for you and I know the guys will want to know this. what master cylinder do you run with 4 wheel discs?? Yea, i know, i asked before but I have 'misplaced' your answer.
TOFIC
TOFIC
Here are some pictures of what to look for. I pulled these parts but have not installed them yet. I'm kicking myself because I always write down all of the vehicle Id information when I pull a part so I know what to order replacement parts from. I lost my dumpster diving note book with all of this valuable data. I do know that it was mid sized ford 4 door sedan with a big bearing 9 inch, positrack (or whatever is was called) coiles springs... It had 28 spline axles with 5 on 5 flanges. The bearing retainer/calliper bracket is a two piece unit held together by two large bolts.
So TOFIC, I'm assuming you have to re-drill the hole pattern in the bearing retainers/caliper holder brackets to use on your small bearing housing, correcto??
Todd Z.
nope, NOT QUITE. the bearing retainers are intact. I had a couple of axle end plates made with the big bearing pattern (15 bucks) and cut the old small pattern axle end off and welded on my new "big bolt" pattern end plate. Have pictures of this if you would like to see the end result. A little work, I admit, but well worth it on the conversion. I am a little nervous around cast everytime I try to do something with cast it breaks.
Yes this disc setup in these pictures are 78 Lincoln.
Yes I redrilled the rotors, picture of my pattern sheet in the first posting. Real easy to do, took me about 10 minutes a rotor to drill and fit them.
now, I am off to the UJerk yard for a dodge truck master, mid 80's to early 90's right Todd??
TOFIC
Ah, ok, the missing link to convert from small bearing to large bearing . Yes, you are right on your years for the master cylinder.
Todd Z.
AGAIN not quite, I had the mounting plate changed, not the bearing end.
I made an end plate out of 5/16 plate and welded it onto the end of the axle.
What I did was grind off the mounting plate and welded on the new plate with the large bolt pattern. I still have a small bearing rear end.
Follow what I am trying to say???
TOFIC
I am reviving this thread because:
1. I am sick of searching for it.
2. I am looking to improve slightly on the bolt on aspect.
Let me explain, I have the same rear Disc brake set up that I am getting ready to add to my 74. I also have a BB rear end and I have not decided yet on if I rebuild the BB or modify the SB under the 74 already. The real issue is that I have hooked up with someone at a brake supply house that specializes in this kind of stuff and has done this mod to 100's of stock cars.
So my dilemma - I need to know if the offset is different between the SB and the BB and also the donor axle. This guy who is helping me out is going to help me find rotors that DO NOT have to be redrilled, or atleast that is my hope, so everyone that has any info about this mod what so ever, chime in! I want what rotors have worked for you and what you have had to do to make them work. I will share the results as they become available. Any measurements such as diameter, offset, etc.
I can sympathise with you on this.I am reviving this thread because:
TOFIC
