sep 21 at 1:00. Bocci needs some help. looking to do a couple of things:
1. park brake connected (have the front cable and foot pedal mounted, will get the rear cables in time as there is no holes in the glass body for mounting the equalizer.
2. front fuel tank fitted and installed (has sender already)
3. Steering column bracket removed from one Bronco column and adapted to an F-series deal
4.the biggie! need a big help with the wiring. not my strong suit by any means. using an E-Z 21 circuit harness and it's roughed in to where i think it needs to go. thoughts and suggestions are welcomed.
I need to work till 12:00 so one would be good for me. if you need directions or can suggest something else i'm all for it. There WILL be some work getting done, unlike last time!![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
