Eoth
- Mar 10, 2004
- 1,680
I always consult this board before my next "upgrade" to see what others have done and hopefully avoid any "pitfalls". So here is a little contribution...
When installing the Borgeson box they tell you that you will need their "DD universal joint". Great, so I bought it.... Well As I discovered "DD" refferes to the shape of the shaft that slides into the upper piece of the lower telescoping steering shaft. SO... If you power steering is from 74 or 75 you do not have a "telescoping" steering shaft (safety feature that came out in 76) and therefore the Universal Joint will not fit (plus it is too short). So I went out and bought a used 76-77 lower steering shaft.. My next problem was a mating issue at the Rag Joint (not sure if it was due to a PO or you cannot interchange the two styles of shafts). After I mixed and matched parts (and some redneck engineering) I made the connection.
So now everything goes together and "works", however the steering shaft is telescoped so far out that only about 1.5" (out of about 12" possible) is still engaged. Not liking that, I went to flea-bay and was able to buy a longer "DD" steering shaft for another 12 bucks... Now everything works as it should...
I hope all that makes sense.. Without the proper telescoping steering and the longer "DD" shaft my afternoon project turned into two weeks of down time waiting for parts.
