hold24
New Bronco owner here. I've been reading about bracing the body before removal from the frame. Do you have to do this with just a small amout of rust in the front floor boards. The rest of the body is super solid.
I made two spreader bars that fit perfectly from one side of the bed to the other and bolted them in place so the bed rails wouldnt spread apart. I then welded up some (bird foot) looking braces to put between the door posts on both sides. This is very important to brace here because the body will bow without support. They worked flawless. I made them so they would use the oroginal hinge holes on the front post, and maunted to the rear post with two screws where the striker usually goes. Easy on and easy off tooHope that helps
Blue71
Blue71
