Brake booster problems
DonH
WA State 30 miles from the beach
I have installed a complete power disc brake system. I tryed to bleed the system. When the brake pedal is pressed to the floor, the brake pedal returns very slow, about five minutes. The booster is resticting the return making it imposible to manual bleed the system.
Is this normal. The motor has not been installed.
Has anyone had this problem?
ssray
South Central NE
I’ve been installing a hydra boost in a Buick Regal but haven’t noticed behavior like that. You might edit and mention if its vacuum or hydra boost as it might help someone diagnose. If you lose vacuum/hydraulic pressure either system is supposed to hold some reserve for several applications of the brakes, after that the pedal pressure needed will get high but should still function. Might be extra drag in a hydra boost if it is dry with no oil in it but 5 minutes sounds like a stretch for that. I can confirm that a hydra boost system does take huge pedal pressure to brake once you lose all the boost pressure.
Scott
Apogee
Tangent, OR
Normally a slow pedal return with a vacuum assisted power brake system indicates an air valve failure which isn't allowing the vacuum to return to the firewall side of the booster, however if you have no engine, then I would assume this is occurring without any vacuum being supplied to the booster.
When the booster isn't supplied with vacuum, it should be a straight through mechanical connection to the master cylinder, and there are return springs in both the master cylinder and booster that should push return the pedal after each application. What happens if you pull up on the pedal? Are your pedal linkages all working freely without restriction? Do you have a picture or a part number of the booster/MC assembly you're using?
Tobin
Rustytruck
Make sure the shaft between the booster and master cylinder is not too long not allowing the master cylinder piston not to fully retract. their is supposed to be a minute gap between the rod in the booster and the master cylinder piston. do you have it on jack stand? try to rotate the tires after you release the peddle.
