csmith441
Is it normal to not be able to get the Snap Ring back on the end of the axle to hold the manual locking hub in place ?
I've read the Tech Article and it shows a bolt and washer, my kit from Graveyard states that the outer clip will no longer be used. It seems there are different views of the spacing allowed for the hubs.
I have mine together and the slot where the Snap Ring attached to the axle is still inside the spindle and it will not come out any farther. I installed the gasket (Rubber billowy thing), spacer and inner seal before I put the spindle and backing plate on the knuckle. Would the spacer that came with kit cause this issue??
Or I put a bolt and washer and call it a day? If so what is the size of the nut needed and thread pattern..
Chris
P.S. Sorry if this is already a thread. I did look before I asked.
Chris
