I have Explorer rear disc, Chevy front disc on a 69 with hydro boost. Haven't appllied the brakes with the engine running yet, so haven't tested the hydroboost at all. I have a brand new WH heavy duty master cylinder advertised as specially set up for hydroboost, bench bled using the plug method. I have the WH Moab adjustable prop valve. I have new calipers on all four corners with new pads and new lines from front to back. Using the H block with WH flex lines running from the prop valve to the H block. I cannont find a leak anywhere, but when I bleed the brakes with a friend's help, the brake will feel firm, then a minute later if I apply the brake I have to pump it up again. What am I missing? The reason I have a new WH MC is because I was spitballing the problem and replaced an older WH MC. I was thinkning about removing the prop valve to see if it made any difference. I have only a few things left to make the rig road worthy and these brakes are driving me nuts!
