Brake pressure issues
ksbronco75
I had a section of brake hose replaced last year. No issues until recently. This issue Aldi does t occur with every trip. But sporadically I will have the brake applied at a stop light or something and the pedal will slowly sink to the floor. Usually a pump or two and the brake is firm. This slow sinking just started and like I said happens let’s say, every 3rd stop sign/light on a trip. Any guesses? I’m not losing fluid or showing any leaks
Master cylinder is failing. Fluid is leaking past the seals. Sometimes the extra pump will be enough that the seal will sit just right and seal. Or you catch it where it doesn't seal and the fluid leaks past. That is why it happens sometimes.
This is pretty common on old brake systems after some part has been replaced.
abn373
Charleston, SC
Damn, I have been dealing with this problem for 15 years (the sinking pedal) otherwise the brakes work fine. I had it professionally bled and it didn't solve it. I guess I need to look into a new master cylinder too. Its a little unnerving when it happens.
Apogee
Tangent, OR
X2...master cylinder internally bypassing fluid assuming no external leaks. It's a sealed system, so if the pedal sinks, the fluid has to be going somewhere, and in most cases, it's back up into the master cylinder reservoir. As stated above, it's not uncommon to have the master cylinder fail (or begin to fail) shortly after bleeding the brakes, especially if you go long intervals between bleeding the brakes. Under normal operation, the pistons can only move so far in the bore of the MC before they hydraulically lock, but when you bleed, you're stroking the pistons the full length of the bore, which may have corrosion, pitting, etc on the bore wall and can damage the seals.
I'd replace the MC, doing a plugged-port bench bleed first, as this should tell you whether the new MC is good or not, versus recirculation bleeding which does not provide any definitive feedback. Once the MC is fully bleed with plugged ports, it should hydraulically lock with minimal piston stroke (~1/8") and shouldn't sink over time with steady force. Assuming that is the case, I'd install it, hook up the rear brake circuit and bleed that circuit only with the port to the front brakes still plugged. If the lines are already full, I'll crack the fittings at the MC and bleed out the air there first and then flush the system if you need/want new fluid everywhere. Next, the the same with the front brake circuit and then you should be done. I typically flush my brake system on my older rigs every 2 years just to keep the fluid fresh and prevent corrosion.
ksbronco75
ksbronco75
Thanks for the quick responses gentlemen. I’ll be looking into the new MC. And you’re definitely right abn373. It is very unnverving
