69Early
I had a brake fluid leak in the line from the master cyl at the coupling to the proportioning valve and lost mucho brake fluid. Repaired the leak, filled the master (both reservoirs) blead the brakes and they seem to work fine. However, the light on the dash below the ignition switch is still on and wont go off? Any ideas on what to look for as a problem. Dont want to loose my brakes if there is something wrong or is it a light error problem. Is there a reset or something I dont know about ??? Something to do with power steering? All suggestions would be greatly appreciated!
