Wild Horses has these dual brake line mounting tabs in their MOAB kits, I’m wondering if anyone has seen them somewhere for sale (just the tabs).
I’ve done some searching but haven’t found anything like them.
Hi, that looks like it would be pretty easy to make, after you find a piece of metal the correct thickness for the horse shoe clips to hold the brake hose.
Good luck
Have you called WH to see if they'll sell the bracket separately? They're clearly getting it somewhere and most businesses like to make money if/when possible, sooooooooo...
Chuckji - what did you end up using for this application? I'm also in the process of installing a Wilwood MC and proportioning valve, and removing the H block. I think I need to fabricate new lines for that, and was looking for a support bracket for the brake lines in that area.
I recently installed a hydroboost system and called Wildhorses to order their braided hoses. I asked about the bracket and they had them in a kit with the hoses and maste cylinder adapters.
