I’ve got several brake line systems to do, and current plan is to use nickel copper lines on frame top side, and need some help.
1. Any advantage in using AN fittings ?
2. Bending tool needed, and if so, recommendations?
3. Hydraulic flaring tool worth costs, and recommendations?
4. Use flexible SS tubing for lift distance to disc brakes ?
5. See any advantage in placing NiCo inside PEX for off-road rig ?
6. Use brake line clips from Bronco vendor or other ?
