- Jul 9, 2006
- 29
Ok, remember that I am all thumbs when it comes to electricity. Primary problem began with starter not stopping, kept on cranking...had to disconnect positive lead on battery. Realized ignition would not go to ACC...so, I replaced the switch. Fun time! Same problem existed: went to Duffy's "Bible" and realized the starter solenoid is on inner fender, right side. Found this baby, lightly tapped it with my hammer, removed that red wire with soft black cover, then placed it back on the terminal. Went to turn key...damn thing started!
Starter stopped when I let key move to ON position. Felt really good and finally somewhat smart....until:
I noticed that little red lite on the right side of the ignition switch was "on" and red...turned the key to each position, the red brake lite would go off, until I took out the key. Started feeling really bad and super dumb!
Checked my wires under dash...seem ok. Note: Vehicle has 92 mustang 5.0 motor with Fuel Injection. Noticed wires running underneath super external air filter in front of mass senor: wondered if rubbing might have shorted a wire...
Ideas? Copy of 76 wiring diagram? All thumbs and bummed out...
