Brake Master Cylinder conversion charts
Madgyver
Bronco Madman
I'm looking to replace my MC today but none of the auto stores have them in stock or non-stocking item. When asked for application 66-77 Ford Bronco, 70 Ford Bronco, 77 Ford Bronco with discs, nothing available!
What else brake master cylinder can I use?
I may resort to the chevy part# and drill/grind the mount holes to match the vacuum booster.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
'79 Lincoln town car will bolt to the firewall/vacuum booster and has the ports on the passenger side for hooking up the lines. However, one of the fittings is a different size, so you'd need to find the correct fitting and re-flare one brake line. I've been running the Lincoln MC for years.
Greg H
Cedar Rapids IA
I just rebuilt the power brakes on my 1970, changed the Master Cylinder. I think it was a 1978 or 1979 F150 MC with 1976 Chevy Blazer calipers.
I have no idea on original parts.
Good Luck!
Madgyver
Madgyver
Bronco Madman
I found a 79 Bronco new MC in stock $37.
Time for me to work to make it work.
