castone001
Folks,<br>a bit of guidance please. 1971 Stroppe 302 Drum brakes all around.<br>Recently, two months, installed BCBroncos Powere Brake Booster. Other<br>day the pedal went down way too far. I bled the brakes and did get a<br>little squirt of air from the right rear all others where fine. Brake<br>pedal now back to normal.<br>Two days later, hopped on the freeway and Brake pedal was fine. Drove<br>for about 75mins at 70mph. Hit the pedal on the off ramp, brake pedal<br>went way down.<br>Limped home and found that the fluid in the front reservoir (Front<br>for the rear brakeline and the rear reservoir services the fronts) was<br>down to half again.<br>I visibly checked all tires, rear backing plate and found no recent<br>leaks? Where did the fluid go? Should I change the wheel cylinders?<br>Any thoughts?<br><br>Thanks,<br>Chris<br>not so stoppable '71 Stroppe
