I don’t know if this is a common issue or not, but someone, previous owner or factory, had brazed the steering stops on both sides. This wasn’t a problem with smaller tires, but when I went to 33” tires, the inner tires will run into the radius arms when steering is cranked over. After mulling it over for a bit, I fabbed some sleeves using the Tractor Supply parts house. These steering stop extensions have to be tapped into place, and I put an 8-32 set screw onto them for additional security. 3/8” fuel hose is glued in the ends to provide a soft stop. 1” length worked best, about 1/4” longer than the brazed stops.
Works great!
