Broken tap help
demesauce
Shaver Lake, CA
So, I was replacing my intake the other day (more like a month ago). 2 bolts broke off in the process, luckily 1 was easy to remove. I was able to drill second one out, but as I was re-tapping the hole, the freaking tap snapped off, in a bad way. There was no material above the surface, in fact there are a few cm between the surface of the head and the top of the broken tap. I think my only option is to slowly drill away at the tap. I have gone through drill bit after drill bit with little to no improvement.
My question to the forum: any tips or tricks to remove a broken tap? Special/different drill bits? I heard small masonry bits may work. I have been using cobalt to try to cut through the hardened steel.
All this just to install a FiTech..... Better be worth it
Readhead
They do sell tap extractors I have had some luck which them I will attach a pic
Bronco4x4
You have to count the flutes on the tap and order the correct extractor type. If this doesn't work use a solid carbide drill bit. Be careful. >> very brittle and wear safety glasses.
B RON CO
Statesville, NC
Hi, I've seen the Wilton tap extractors and they are expensive.
I think a carbide grinding butt in a high speed die grinder will work.
Good luck
tirewater
San Francisco Bay Area
Use carbide drill bits. Cobalt drill bits will quickly dull and be useless in a matter of seconds. Keep lubricated, and blow away chips as they store quite a bit of heat which will cause problems.
If you want to tempt fate, use an easy out...the biggest that will fit. Of course you run the risk of breaking that as well.
demesauce
demesauce
Shaver Lake, CA
Thank you guys for all the info. I think I'm finally getting me re-motivated to try to remove this tap.
Rustytruck
Take the broken tap and with a cut off wheel and cut down the center of the tap to mak fingers that fit in the flute of the broken tap and back it out if it is not stuck too bad. If that doesnt work get a dremel with a small carbide burr and bore the center of the tap out. Most of the time works better if you use a sall diameter grinding bit. If it wasnt a intake bolt you can use a center punch and fracture the tap and dig it out with a pick piece by piece. With the head the intake bolts are too close to the edge and hammering on it will break the head. What ever you do drilling a tap is a looser. Just dont do it. The head will drill and the tap wont and your screwed.
Crawdad
I’d use a carbide bit and a pencil grinder. Get some good hearing protection and good googles that won’t fog up. Grind away. I break ez outs and the only way is a carbide bit and a lot of spare time. A good magnet is good to have by unless you like sharp pieces (FOD) sticking to ur clothes only to be washed with other clothes. I’m a machinist in the AF and I remove tons of stuck screws.
Howard2x4x4
Happened to me today! I was going to start a new thread called "Kool Tool" 'cause I didn't know these things existed! I was using a 1/4 -20 tap into a SS and zinc grill piece and the bugger snapped! "Hecky-darn" I said, and then I thought now what? Well, I had just been to Lamb Industrial in Holyland to pick up some drill bits, so I went back to see if they had some over my budget drill bits that would cut into a tap, and yeah, they had an 1/8 carbide @ $17, AND they had a tap extractor @ $9. I bought both and the tap extractor worked really slick, almost made me want to crack off another one. I fought the urge. Good luck!
bronkenn
Bronco Guy
Southeast Ohio
Golly geeze! That looks like a dandy tool Howard. And it worked.
Howard2x4x4
Worked really slick, Ken! I did a little more than the story sez, like using a Dremel to clean up burrs at entrance and exit points, and a drop of Marvel Mystery Oil, but it was pretty much a piece of cake! One piece of advice that truly manly macho men mechanics don't often heed is, "Finesse, not force."
demesauce
demesauce
Shaver Lake, CA
Thanks guys I was finally able to drill it out with my SDS rotary impact hammer. Normal impact driver wasn't doing the trick
