BD
I just picked up a second bronco up over the weekend.
I am going to take the two bronco's and make one really good one.
Here are the contenders.
73 - 302,C4 shift on column,4.11 limited slip, powersteering, 4.10 Dana 44 front disc brakes, 3 1/2" suspension lift with blocks under stock rear leafs, new dual dynamax exhaust. body is metal but needs tons of work.
74 - 302, 3 speed on the floor, powersteering, 3.50 open, fiberglass tub and body parts. 3 1/2" looks the same as above, needs new bushings everywhere, needs body mounts, rear drive shaft, and need new exhaust.
I have a Termec 4speed OD to put in from a 87 bronco.
which would be the better route.
option 1. Take metal body off 73, change c4 with manual OD using all parts from 74. Install fiberglass on 73 and rewire.
option 2. Move 4.11 axles to 74, swap tranny, replace bushings, move rear drive shaft to 74 , replace body mounts. move(replace) exhaust
if anybody thinks of any other options, let me know.
i can wait to start making frankenbronc!
Brian
Brian
