gearida
I have a new hood, it has caused me to redo the air cleaner, due to I side clearance. Even though it is a mid rise hood the interior panel of the two piece fiberglass hood is not raised. But now I am looking at the hinge fitment now. The interior panel doesn't allow a nut n the back side or inside without cutting out a large hole for access. So I am thinking of a nut insert which will expand in the hole from the rear or outer edge. Has anyone purchased this hood with the two layers? I really don't like thinking I will cut a hole which will allow water between the two panels. I cut out the vents near the windshield where I may try putting sealer in between the upper and lower panels. What do you guys think?
