Bronco hut exhaust fit 351/4r70w
jcb9089
Attempting to fit Bronco Hut exhaust. I have 351 block, 4R70W trans, Bronco Hut headers.
Just doesn't feel like it's going together right. Does anyone have pics on install with similar setup?
The driver side pipe fits really tight up against oil pan and trans...is this normal? I'm running oil pan for 351 from vendor: https://shop.broncograveyard.com/Oil-Pan-Kit-351W-66-77/productinfo/10115/
When snug, the pipes don't align close. I can make it fit but it's not optimal.
Is this too close to trans and oil pan?
SDBMtber
I think the oil pan is your problem. I have the bronco but headers and exhaust and 351W. I believe the exhaust is setup to tuck into the recess in the oil pan at the back near the transmission. Not sure what all had this type of pan, but the 90s trucks did. The oil pan you linked doesn’t have that recess so I don’t think you’re able to fit into that area very well.
I don’t have any pics handy showing this but could take one tonight if it helps.
I wasn’t able to use that type of pan for that exact reason. But, I haven’t had any issues with the dana 44 hitting the pan, with some extended bumpstops.
Viperwolf1
electron whisperer
The later pan looks like this.
SS396
Newbie
I had the same issue, also with 351 but I'm not convinced that the 351 created the fitment problem. After messing with it for a week I took it to the exhaust shop and they had no luck either. They had to fab a new Y pipe to make it fit.
jcb9089
jcb9089
Thanks all. I took off pan and test fit, might be able to pull it together with new pan but still doesn't feel right.
New pan will be here this weekend...hope pickup tube matches old pan.
jcb9089
jcb9089
Update
Update...I spoke with Dana, original Bronco Hut owner.
He explained their system is designed for 302 but to make work on a 351, need to do the following:
1. Weld 1" extension on passenger side pipe that connects to header...where joins y pipe.
2. Extend driver side pipe as far as can and weld, not clamp.
3. Use oil pan with dip, like viper shows in his pics.
4. Weld together except y pipe joints. Can remove entire welded exhaust from rear of bronco.
Hope this helps anyone that runs into the same problem.
