OffRoadOhio.com
After two years of very rough treatment I have decided to retire the stock Bronco II drivetrain in my 85. The 2.8 is on its last leg, and the Dana 28, is fianally falling apart from being welded and running 33's.
Here is what is going in.
240ci inline 6 cylinder
RAN 3speed Manual
Dana 20 (twinstick)
Locked High Pinion 30 from Jeep Cherokee
So last friday I pulled it in the garage to begin work. In just under two hours I had the Dana 28 completely removed.
Last Saturday the g/f came out to help and wrench on her BII's.
We managed to cut the nose off of, unhook the engine wiring, remove the front bumper and reinstall the hatch glass
Last Sunday we managed to get my old engine pulled, and remove al lthe good left overs, carb, alt, ps pump, etc...dropped the tranny and tcase aswell. Also got the old Sponsor stickers removed from the rear glass and added a HUGE www.OffRoadOhio.com sticker
This week ive been mostly waiting on parts but I've got the 4.10's new seals, locker and new joints in the d30, and got the tcase gutted, for a seal/bearing replacment, and of course to grind the shift rails to twin stick it.
Also went and got the stuff for the "long arm" style arms im building for it.
First went and bought two top links and lift forks from Tractor supply.... then realized I had my buddies old 4link setup from the back of his bII so I stole the top arms to use as my bottoms, and kept the lift forks for the upper link.
The 4link arms I have work perfect to sit it just behind the body mount ( 6 inches longer than stock BII radius arm) and the lift forks fir the top link mount perfect and angle it exactly right to bolt to the lower arm where i needs to be to clean frame and such.
gonna start mounting the axle tommorrow once I get the RIVETED on cross member out of the way...
The one issue I need to figure out.... leanin backwards coil springs.... I centered my axle under the cross member to elimnate cutting it, and make u pfor some winch overhang (yes it gets a winch too) Now I know them leaning wont hurt them but it bothers me, cuase I want em straight, so it comes down to moving either the axle buckets or frame buckets..... not sure which I wanna do yet.... axle looks like PITA. Obviously none of my links are hooked up yet and these photos are of axle "test fits"
gutted tcase
RAN 3speed Manual
Dana 20 (twinstick)
gutted tcase
