Bronco in iceland
gotdads68
Found an early bronco in Iceland last week!
spap
Thy always run those giant meats in Iceland got you float over the snow
spap
Rear seats look like lounge chairs and the exhaust comes right under the rear tank unless they moved it
gotdads68
gotdads68
Rear seat is a bench that goes the full width, from what I understand they cut down the rear wheel wells to fit the wider seat. I think that's why the rear sheet metal is all welded up to create a separate compartment behind the rear bench that's only accessible from the outside to keep heat in. I wanted to look closer at it and take more pics but I was getting eyeballed pretty hard by the employees at the shop it was parked in front of.
73azbronco
They were probably hungry and you were the first piece of meat to walk by this season.
