the-glove
My 67 leans to the passenger side quite a bit, more in the rear than front. I’m aware of the affect the C bushings and the torquing of the cap bolts can have on lean. Before I go into the whole taking apart the front end, leveling the radius arms and torquing down the radius arm caps in the X pattern, I was thinking….wouldn’t an easy way to diagnose or rule out the C bushings/caps as the culprit be to take off the front wheels and put the front frame on jackstands? This would take away the impact the front suspension has on any lean right? If this takes away the rear lean, it means it likely is the c bushings/caps causing it. If it’s still leaning, that probably means it’s something else. Would this work? Thanks in advance!
