74bronk
- Sep 1, 2004
- 358
Back ground info: I have a 302 with automatic trans and a 4 barrel Holley truck avenger. Had this same problem last year only I adjusted the jets down and it passed then afterwards turned them up to run better. This year I adjusted jets down again .... It didn't pass so I took it home again put a tach on motor checked the Rpm at idle about 700. Adjusted the jets down (so I thought) decided to try and adjust the floats In the bowl. not a good idea haven't touched them in years. I took it back up to see if it passed this time it was worse! Instead of 768 parts per million it jumped to 989 per. (Supposed to be bellow 700!) help im stuck need to get this fixed before the dec 22
