I am having issues with my Bronco just quitting on me. It has been running fine for a couple years now. It happens sometimes while driving, other times, just wouldn't start. I assumed it was my FITech and FCC2, so I pulled it and put on carb. Still having the same issue. Bronco will crank but not fire. I am getting fuel (also have used starting fluid). There seems to be no rhyme or reason to when or where it happens. I checked all grounds and connections. Replaced the coil. Battery is good, Centech wiring harness with a one wire alt. I do have a Crane ignition module (similar to a Petronix) that is probably 15+ years now. I've ordered a new Petronix and it is on the way. Any thoughts?
Thanks,
Will
Thanks,
Will
