Bronco Road Trip!
BajaBronco
Well, the time has come finally. My girlfriend and I have been
planning a road trip since December. My parents are celebrating their
40th anniversary out in Wisconsin and we need to be there...plus the gf
hasn't been across the country in a car...just planes. So we figured, why not drive?
Originally we were going to take my 62 Mercury Meteor with 5.0/AOD, but somewhere around May, Kuttysark found me a Bronco Four Wheel camper in Colorado. There was a thread about it, which I stayed out of mostly because I was working out a deal to buy it already. Well, plans quickly changed and instead of working on my Mercury I looked at the driveway and decided that my 72 Tampico Yellow Baja Bronco would be the best candidate for the camper installation and a smooth trip. All stock in case something breaks, and relatively comfortable/quiet.
Here's how she looked when I bought her
I bought this Bronco last summer from the 3rd owner and hadn't done a whole
lot to it. It had been sitting for a long time, but was complete and always
seemed to start right up. I applied the "drive til it breaks" theory all last year and
sure enough I ended up rebuilding the carburetor, heater, all hoses,
timing cover(corroded all the way thru let go one day at Chipotle), water
pump, timing chain, belts, fuel tank(dirt packed between skid plate and tank
rusted it out), lines and hoses. Overall it drove well, and got us
to Yosemite and back, but I decided that taking a big trip warranted
a check of all other systems as well.
I began with the brakes and ended up changing all wheel cylinders and
rubber hoses. The truck stops well with original drums and small tires.
The hardware was pretty fresh and in terms of the shoes, and drum
surface, I chose to leave them alone - just clean and adjust correctly.
Amazing how well correctly adjusted, lubed drums stop.
The transfer case, transmission (3speed), motor dont leak. Maybe
it's all the clay from years of hunting, but I also think that benefitted
in their general use, keeping the seals pliable. T-case goes into 4wd
easily.
The hardest part was taking the top off. It had never been off before
and I had a hard time making myself do it. But no way is the Four
wheel Camper going on with out it. Off came the
tire carrier and associated brackets/latches. In order for the camper
to go in, there can't be any speakers, latches on the tailgate, or
brackets inside the 'bed'. I learned that the hard way with my first
Four Wheel Camper, getting it almost all the way in..then out...then in..then out. So when I get to Colorado to retrieve it, I'll take off
the tailgate latches and I'll also remove the rollbar and that'll be it.
After that I tried to think of what else made sense to do. I checked
the body mounts and they were the original rubber mounts and mushroomed
quite a bit, so I installed new urethane mounts and hardware. I figured
with the extra weight on the body it'd be nice if the body was more
solid to the frame. Normally I like rubber body mounts.
Towing mirrors were another item. Stock mirrors dont let you see
around the camper - too wide. I just didn't like the mirrors
that Ford offered from the late 70s - 80s. I really wanted Roadster
mirrors with adjustable bars, but at the prices those fetch, I decided
I'd find something else. '78 Dodge van worked out well with a bracket
tweak and they are stainless.
Last, I got a decent stereo with MP3 and ipod cables with remote. FIgured
the remote might work with the back door of the camper open, sitting by
the fire. I also installed an oldschool Tuffy box with no radio compartment...
drinkholders were a must.
I pretty much had it all ready to go until last Monday - the throwout bearing was
making a ton of noise, so I put a clutch in....it was about due
anyway. I really wanted to go back to automatic, but maybe after paying
for gas across the country, and with a new clutch, an NV3550 swap
is in the plans?
Looks better with a new clutch, huh?
We are headed from San Jose
to Reno, then thru Great Basin, Denver ( to get the camper and spend a
day installing ), then either out to Iowa, Chicago, Twin cities, or a more northern route via Bad Lands
and Mt. Rushmore. Then on to our summer spot on an island in Lake Superior.
I think we're ready. I'll try and post pics along the way...not sure how well it'll work with the internet connection. Get your spare parts ready!
sprdv1
REBEL
LOL. Nice man.. I bet that top was a big PITA.. Safe journey to you and the GF.... Looking forward to the Pics...
mustangtoby
southwest Colorado
You've got a large sack, my friend! That is a heck of a trip in a rig that old. I have made a couple of 12 hr drives in some old iron, and also spent some time on the side of the road working on them (although your baja is in great shape, much better than my old 65 F-100). Good luck, looking forward to reading about the trip, seeing pics!
TN1776
Awesome... Sounds like a trip I'd like to take in my EB one day. Have fun and be safe.
NicksTrix
have fun you two. don't forget the sticker for the camper..
if you see it rockin' don't come a knockin'.... ;)
seriously, have a safe & enjoyable trip. if you need any parts along the way call me and i'll overnight you them.you know i've got a good cache..
enjoy my friend~
ManTruck
Sounds like fun. Send me a PM and we can get togeather if you like or you can have a place to stay a few days.
I will also give you a hand on the install or if you need some help with your ride.
Dave
aughtsix06
kaneohe,hi
You must be one heck of a salesman to convince the GF to brave that one. good luck and i bet you have a great trip even if things dont go as planned.
grant_71
Need Pics of girlfriend...
But really, that sounds like a blast, have fun.
BajaBronco
BajaBronco
Ya, I'm okay at sales, but really it's her fault for being pretty adventurous and low maintenance. It will be an adventure for sure, like you say, planned or not!
neonizagas
Minneapolis, MN
I'm located in the Twin Cities area. If you need assitance with anything during your adventure - when you get this far let me know. I am involved with the Midwest Vintage Bronco Club would be willing to help you out if needed!
Gerry
NorCalBronco
Damn I'm jealous! Have a great trip and take pics for us, especially of that camper.
BajaBronco
BajaBronco
Whew, we just made it to Grand Junction,CO. Reno the first nite was good....tho got there too late to visit the Stroppe racer at the museum. Next day was on thru Nevada on 50. Stopped off in Fallon to see Glenn from Broncohunting.com. He's got a great new bldg going up and hooked us up with a new seal for the camper. We had our first breakdown (and last), coming into great basin. Rear driveshaft cv went out....we limped 100 miles to the nearest parts store....in Delta, UT. Of course no idea what a Bronco would need and no driveshaft store...so I went outside and looked around to see what I could see...and there was a 72 Bronco sitting next to a shop! Sure enough, the shop owner is an EB guy. He set me up with a creeper and I pulled the driveshaft. He had me back on the road in 1 hour with a new cv. I still have a dl vibration so I'm on the lookout for a Good stock hite rea driveshaft in Denver area tomorrow. Gotta try something out... I noticedvthat someone years ago clamped the shaft and pinched it....it was also clocked wrong and the folks in UT corrected it.... But how was it orig balanced? Anyway, having fuuun!! Aweso sites in Utah. Had rain, but at 65mph we didnt get wet. My girl has driven about 40% of the time and has endured the EB trip effortlessly thus far. Camper pickup tomorrrow!
Rumpfy
San Jose, Ca.
You're nuts AN.
Your GF gets major, major points to not only making the trip with you, but for pulling 40% driving duty!
