Bronco Weight
asappin
I am trying to figure out the weight of my bronco to determine if I will exceed my towing capacity for my 2016 4Runner Trail edition. The towing capacity is 5,000 lbs and I will be using a UHaul car hauler. Stats on Bronco below:
1969 Bronco
302 with 3 speed transmission
Fiberglass Roadster inserts
No hard top
Dana 30 Front / 9" Rear
Carpet interior - no bed liner spray
Stock bumpers front and back
33x12.5x15 tires. Spare tire on back but it won't be making the trip
Thanks for any input guys. Pic of truck for reference below
Slowleak
Georgia
My guess is that you will be over. Figure about 3800 for a stock Bronco. Then subtract 125 for the top, 60 each for the doors, and you are at 3555. The trailer weights 2210. That puts you at 5765 lbs.
Timstrk
A car trailer or two-wheel dolly? With the trailer, yes. With the dolly, no. But close. Their trailers are heavy and for a reason. The real issue isn't going but stopping. The trailer weighs almost as much as your tow vehicle. Not the best without trailer brakes.
ep67bro
Bronco Junky
Easton, MD
You will be over and as other said stopping is the problem. I know my bronco is every bit of 4,000 lbs. But I do have more weight in mine like doors, 35" tires, NP435 trans, and soft top.
Crush
Greenbottom, WV
U Haul trailers are HEAVY!! However they have surge brakes on them which will aid in the stopping ability. you will probably be right on the edge of the limits.
sykanr0ng
Surge brakes are not very good trailer brakes, better than nothing but that's about all you can say for them.
Rustytruck
Rent a tow dolly. I bought a tow dolly with electric brakes and my Bronco towed very well with it. Remove the rear drive shaft. Time to move the Bronco on and off the dolly. Lock the hubs and drive off in 4wd. 20 minutes to remove or replace the rear driveshaft. Be sure to duct tape the u-joint caps so you don't loose them or drop them in the dirt. Dont forget a blanket to lay on under the Bronco. Remember if your not in 4wd and remove the rear driveshaft the Bronco will be subject to roll over you if you don't take precautions. You don't want tire tread tribal scars.
Jakedog
When I bought my 69 3 years ago, I towed a tandem axle uhaul trailer for 300+ miles with my 2004 Tacoma 4x4 crew cab. It did ok with just the trailer, but when I put the bronco on the trailer I saw the rear end squat down big time.
I overloaded that poor truck.
My dad was 70 years old at the time, and I swear he hardly said a word on the trip back. When the trip was over he told me he didn't think we would make it home.
He said he was praying the whole way.
The guy I bought it from lived in Fairfield, Ca. It was about a mile up a steep windy road to his house. I remember my dad saying, "there is no way in hell you can tow that bronco down this hill!! It will push us off the road and kill us!" Lol.
When we got to the guys house we saw he had a new dodge dually diesel. He thankfully towed the trailer down the hill for us.
The guy included a new tailgate, windshield frame, rock sliders, carpet kit, fender flares, a stereo with speakers, and boxes of miscellaneous parts.
The bronco had/has an ugly rear bumper that weighs a ton, and an old school tube bumper with a warn winch.
That plus the car trailer was way too heavy.
I was really wishing I still had my super duty diesel.
I towed the 300 miles home with my headlights shining on the underside of overpasses.
I was lucky that I wasn't pulled over by the chp.
I took it real easy on the way home, and I kept plenty of space behind other vehicles.
I think an emergency stop would have been a bad thing.
At least it was a lot of flat ground on i-5 on the way home.
A heavier truck for towing is the only way to go. Especially if you'll be on windy and steep roads.
Fyi- my Tacoma has icon coilovers and 8 leaf deavers. I'm also running 285/75/16 bfg "E" load tires. I think my tires were the only thing on my truck made for heavy loads. Lol
131k miles and is running good.
I wouldn't do it again. Plus, The Uhaul trailers have a surge brake. So it has to push against your vehicle to apply its brakes. I really like my Tacoma, but sometimes I wish I had a full size truck again.
englewoodcowboy
Lick Creek Restorations
Broncos are heavier than you think. I will guess that the vehicle itself is pushing 4K on its own as it is. Add the weight of a dolly or trailer and you are over. I would look at renting or borrowing someone's truck or full size SUV then rent a trailer. It does you know good to risk things and have a wreck, or worse yet injure someone or yourself due to over loaded weight you cannot control in a panic situation. Could it be done with your setup, sure, I am certain someone has done it, but would I want to be in that setup in an emergency situation, he'll no.
Skiddy
mine to with the spare, winch, tools and my 20' trailer is pretty heave as well loaded with parts, tires and more tools%)
andyp
Rent or borrow a bigger truck, no question about the need for that.
Digger556
Do not tow that with a 4Runner.
The Bronco and that heavy Uhaul trailer will easily exceed your tow rating. Plus any time you are near the max of a vehicle's tow rating, you are working it very hard.
You need a bigger tow rig.
gnsteam
Lincoln NE
I just weighed by stock 76. It came in at 3978, with a full top, dealer installed roll bar and 33" tires. Add heavy U-haul trailer and your defiantly over weight for the 4 runner. DON"T DO IT! BE SAFE!
Yeller
Rogers County Oklahoma
I've towed 5500# with our FJ. Had trailer brakes, it did fine had enough power and stopped well but it was not comfortable. Felt like I had to stay on point 100%, no comparison to pulling 20k at 80 with the cruise on with the f350
Jluck
U-haul won't even rent you a trailer for that configuration. At least around here...
flexmerc
A couple years ago when I bought my bronco, I pulled it with my 14 Jeep Grand Cherokee; it has the towing package, 5.7L and an air suspension..over 7k towing capacity.
The only thing that sucked on the trip was my MPGs, I averaged around 12 for 5 hours :)
Did I mention, I went inside to pay for the Uhaul car trailer and Nobody was outside with the dude rigging up the trailer. Well it was late, close to closing time and my friend Shane came around back with the bronco and I came out the shop to ground guide him on the trailer, as soon as he drove on the ramps the trailer hitch jumped up and hit the hell out of my Jeep! Haha 😆
I look at Shane and tell him well you gotta back up, he did and it came crashing down.
That was the start of a wonderful and pleasant drama free relationship with my bronco, hahah!
End of the story, Uhaul paid for the damages, and always double check that hitch.
