Tech article by Phil Dawson (phldwsnoc1)
After a career of making suspension repairs and improvements to a wide variety of vehicles, it was time to see if I could do the same for my Bronco. Designed with a single adjustment point for total toe, some creativity is in order when you approach alignment issues on these products. It’s also important to bear in mind that unless you are doing a pure restoration with original wheel and tires, factory specs may not be at all appropriate to achieve your desired results.... Click here for full Tech Article
