- Sep 17, 2018
- 250
Different post to address a different issue I suppose.
Truck is a 74 Bronco with a Stock 302, Duraspark ignition with an aftermarket NAPA control box. Spark plugs are Autolite 45's with ~13k miles on them. There's two fuel filters, one before the fuel pump, and one screwed into the carb. Fuel pump is mechanical, not sure how old. Oil doesn't smell like gas.
Driving down the highway at about 70, truck starts to buck. Try to power through it, bucking gets worse, engine will die for a good second, then come back for a second, then die, etc. Pull off the highway, foot off the throttle, and the muffler explodes. Now, truck is running fine at 60, but if I try to get up to 70, it starts bucking until I let it get down to about 50, where it recovers and can cruise at 60 again. Engine is smooth at idle, with a slight ticking that's been getting slightly worse over time.
Any ideas? My first thought was fuel delivery, but if it was starved that bad, would the muffler be able to gather enough gas to explode? Do the ignition modules/other components fail in this sorta fashion?
I'm probably going to throw a new fuel filter and plugs at it tonight, seeing as they're about due anyway. I'll put up pictures of the old plugs when I take em out.
Here's that ignition module:
![0wvHf1C.jpg](https://i.imgur.com/0wvHf1C.jpg)
