Posting this up for a real good buddy, I know it isn't Ford but figured there might be someone into cool motors here. This thing would be rad in a hotrod or no hood ride.
Buick 215 V8
Built by Mark LaGrou of D&D Fabrications.
-bored to 219 ci
-compression ratio 10:1
-custom Egge pistons
-recond. connecting rods
-new crank balanced
-heads 34 cc with oversized valves
-custom machined crank pulley
-custom machined water pump pulley
-high volume oil pump
-high volume water pump
-160 degree thermostat
-custom machined clockable thermostat housing
-crower cam 276 degrees 488 lift
-new valve springs
-new rocker shafts
-billet rocker shaft supports
-edelbrock intake manifold
-edelbrock carb
-timing chain set
-Hastings moly rings
-pertronix ign no more points
-one piece rear main seal
-oil pan powder coated wrinkle black
-ranger rover valley cover
-arp head studs, main studs, and connecting rod hardware
-Offenhauser valve covers nos machined to give leak free operation
-hybrid clutch z28 flywheel, T5 mustang disc, and z29 pressure plate
Engine builder did a couple hour break in run, and motor is ready to drop in and go.
Any other questions feel free to send Pat an email at Pverdeur@gmail.com or send me a PM and I will get him in touch with you.
Buick 215 V8
-bored to 219 ci
-new crank balanced
-new valve springs
-new rocker shafts
-edelbrock carb
-timing chain set
