Build Thread 1968 (Update 02/01/10) New tranny etc.
Ohio Bronco 21
Ohio Bronco 21
Cleveland
I got my new to me engine. 302 with 351 heads. I did some work on it and cleaned it up (not that it really needed it). I also installed my new centerline clutch, It will soon go into the 68 with the NV3550.
Ohio Bronco 21
Ohio Bronco 21
Cleveland
Engines installed and running, interior is in, most stuff is working. still have to bleed the Brakes (new disc set up) some smaller stuff and an exhaust and I should be on the road.
Ohio Bronco 21
Ohio Bronco 21
Cleveland
OK, I have had her out running down the side street. I still need an exhaust so it is a bit loud. here are some new pics.
76 bronco J
>>>>> I see a engine issue that needs correcting immediately..... it's good your using the PCV valve on the passenger side, but it's a very bad thing for your engine seals to have that driver side valve cover sealed up with that oil fill cap....... you need to run a 5/8" hose to the air cleaner like stock, put a direct mount breather or do a remote breather set up.... I prefer a remote breather with a 5/8" hose going to the valve cover 'cause it keeps both new & older engines the cleanest........
Ohio Bronco 21
Ohio Bronco 21
Cleveland
Hopefully I can find a cap that fits the tall oil fill tube on these valve covers. I had thought about doing what you said but had since forgotten about it. Thanks Where did you get your fill caps that fit your valve covers?
Ohio Bronco 21
Ohio Bronco 21
Cleveland
I think I seen that motor before but for the life of me I can't remember!;D
I still can't believe you cut the truck!:cry:
Job well done even if it's cut!%)
Jeff, I got the engine from some old Bronco Hermit that lived in the wilds of Fairview inside his old 66 U13.
I do plan on having an uncut also, Small lift and 30 inch tires, Fuel injected 6 from a yet to be spoken of source vehicle. Mallard or Boxwood green with a whimbelton white top and grille, stockish interior etc.
Ohio Bronco 21
Ohio Bronco 21
Cleveland
I had an exhaust hooked up. I ran two pipes into a y and back along the transmission passenger side to a simple turbo muffler. I then had it exit the passenger side just in front of the passenger side tire. Sounds really good, Loud if I stomp on it but mostly just purrs along. All the interior sound deadner really makes a difference inside too.
I need to drive her some to get everything dialed in now. COOL.
Ohio Bronco 21
Ohio Bronco 21
Cleveland
Thought I would update this thread. I installed a steel half Cab Top for the weather. Here is how she is now.
