broncnaz is correct. As go the C-bushings (and caster) so goes the pinion. It's hard-wired, so anytime you change the angle of the c-bushings, the pinion will be raised or lowered.
That's why, at some point, c-bushings deliver deminishing returns and put your pinion/u-joint in a bind.
At that point the best way to achieve your desired caster angle and return the pinion to some sense of normalcy, you have to turn the steering yokes.
So the others are correct also. If the c-bushings are on backwards, most of the time you'll know instantly, as it's hard to maintain a straight line! And you can tell by looking at the pinion angle too. That last bit probably takes some more experience with what angles the pinions are at under normal circumstances, but it's do'able.
